00:02:33
33 |
74 |
25 |
21 |
e9f3f226557c602466a1511b78b06893 <h3>Benchmark Results</h3>SfM running times:<b> 33 seconds </b><br>MVS running times:<b> 74 seconds </b><br>Mesh running times:<b> 25 seconds </b><br>Texture running times:<b> 21 seconds </b><br>Overall running times:<b> 2 minutes and 33 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA TITAN V <ul></ul></li><li>Memory 12287 Mb <ul></ul></li><li>Clock 1455000 Khz <ul></ul></li><li>Processors 80 <ul></ul></li></ul><b>CPU </b><ul><li>Type Intel(R) Core(TM) i9-14900KS <ul></ul></li><li>Number of Cores 8 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65243 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 455426 Mb <ul></ul></li><li>Total disk space 953131 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:02:53
43 |
83 |
26 |
21 |
be6c9459cda001820c89759390dfe87f <h3>Benchmark Results</h3>SfM running times:<b> 43 seconds </b><br>MVS running times:<b> 83 seconds </b><br>Mesh running times:<b> 26 seconds </b><br>Texture running times:<b> 21 seconds </b><br>Overall running times:<b> 2 minutes and 53 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.511 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA TITAN V <ul></ul></li><li>Memory 12287 Mb <ul></ul></li><li>Clock 1455000 Khz <ul></ul></li><li>Processors 80 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900K <ul></ul></li><li>Number of Cores 24 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65243 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 312385 Mb <ul></ul></li><li>Total disk space 953131 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.511 |
00:03:05
37 |
94 |
31 |
23 |
e4dce3386fbfedf2598969288177fac7 <h3>Benchmark Results</h3>SfM running times:<b> 37 seconds </b><br>MVS running times:<b> 94 seconds </b><br>Mesh running times:<b> 31 seconds </b><br>Texture running times:<b> 23 seconds </b><br>Overall running times:<b> 3 minutes and 5 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.511 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4090 <ul></ul></li><li>Memory 23027 Mb <ul></ul></li><li>Clock 2610000 Khz <ul></ul></li><li>Processors 128 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900K <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65345 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1442028 Mb <ul></ul></li><li>Total disk space 1906794 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.511 |
00:03:11
45 |
93 |
30 |
23 |
b5445c31b8e3a68bd2674fe4a9dfb424 <h3>Benchmark Results</h3>SfM running times:<b> 45 seconds </b><br>MVS running times:<b> 93 seconds </b><br>Mesh running times:<b> 30 seconds </b><br>Texture running times:<b> 23 seconds </b><br>Overall running times:<b> 3 minutes and 11 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.507 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4090 <ul></ul></li><li>Memory 23027 Mb <ul></ul></li><li>Clock 2610000 Khz <ul></ul></li><li>Processors 128 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900K <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65345 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1439035 Mb <ul></ul></li><li>Total disk space 1906794 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.507 |
00:03:13
47 |
91 |
32 |
23 |
45d938bee5fe54336228b224700a0e3f <h3>Benchmark Results</h3>SfM running times:<b> 47 seconds </b><br>MVS running times:<b> 91 seconds </b><br>Mesh running times:<b> 32 seconds </b><br>Texture running times:<b> 23 seconds </b><br>Overall running times:<b> 3 minutes and 13 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.511 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4070 Ti <ul></ul></li><li>Memory 12281 Mb <ul></ul></li><li>Clock 2640000 Khz <ul></ul></li><li>Processors 60 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900K <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 130812 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 505809 Mb <ul></ul></li><li>Total disk space 953204 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.511 |
00:03:14
40 |
101 |
30 |
23 |
e002b83e423f05ef9fa14703b0eb98cf <h3>Benchmark Results</h3>SfM running times:<b> 40 seconds </b><br>MVS running times:<b> 101 seconds </b><br>Mesh running times:<b> 30 seconds </b><br>Texture running times:<b> 23 seconds </b><br>Overall running times:<b> 3 minutes and 14 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.505 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4090 <ul></ul></li><li>Memory 23027 Mb <ul></ul></li><li>Clock 2610000 Khz <ul></ul></li><li>Processors 128 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900K <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65345 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1449404 Mb <ul></ul></li><li>Total disk space 1906794 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.505 |
00:03:16
46 |
96 |
31 |
23 |
1d729e66237c2e68b7bc818e72d8d0a1 <h3>Benchmark Results</h3>SfM running times:<b> 46 seconds </b><br>MVS running times:<b> 96 seconds </b><br>Mesh running times:<b> 31 seconds </b><br>Texture running times:<b> 23 seconds </b><br>Overall running times:<b> 3 minutes and 16 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.511 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4090 <ul></ul></li><li>Memory 23027 Mb <ul></ul></li><li>Clock 2610000 Khz <ul></ul></li><li>Processors 128 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900K <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65345 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1406395 Mb <ul></ul></li><li>Total disk space 1906794 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.511 |
00:03:19
48 |
98 |
30 |
23 |
e3fa9ba373379c569f5aac8338090987 <h3>Benchmark Results</h3>SfM running times:<b> 48 seconds </b><br>MVS running times:<b> 98 seconds </b><br>Mesh running times:<b> 30 seconds </b><br>Texture running times:<b> 23 seconds </b><br>Overall running times:<b> 3 minutes and 19 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.507 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4090 <ul></ul></li><li>Memory 23027 Mb <ul></ul></li><li>Clock 2610000 Khz <ul></ul></li><li>Processors 128 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900K <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65345 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1440544 Mb <ul></ul></li><li>Total disk space 1906794 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.507 |
00:03:22
49 |
100 |
30 |
23 |
7f06f2d11f7aa15f23661ab2aca86cf3 <h3>Benchmark Results</h3>SfM running times:<b> 49 seconds </b><br>MVS running times:<b> 100 seconds </b><br>Mesh running times:<b> 30 seconds </b><br>Texture running times:<b> 23 seconds </b><br>Overall running times:<b> 3 minutes and 22 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.511 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4090 <ul></ul></li><li>Memory 23027 Mb <ul></ul></li><li>Clock 2610000 Khz <ul></ul></li><li>Processors 128 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900K <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65345 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1441836 Mb <ul></ul></li><li>Total disk space 1906794 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.511 |
00:03:23
49 |
100 |
31 |
23 |
61c96d1425427e986ffb96b1381fc146 <h3>Benchmark Results</h3>SfM running times:<b> 49 seconds </b><br>MVS running times:<b> 100 seconds </b><br>Mesh running times:<b> 31 seconds </b><br>Texture running times:<b> 23 seconds </b><br>Overall running times:<b> 3 minutes and 23 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.511 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4090 <ul></ul></li><li>Memory 23027 Mb <ul></ul></li><li>Clock 2610000 Khz <ul></ul></li><li>Processors 128 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900K <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65345 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1442028 Mb <ul></ul></li><li>Total disk space 1906794 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.511 |
00:03:24
48 |
101 |
31 |
24 |
346c0bbe723069a9f3a335daaf0c602e <h3>Benchmark Results</h3>SfM running times:<b> 48 seconds </b><br>MVS running times:<b> 101 seconds </b><br>Mesh running times:<b> 31 seconds </b><br>Texture running times:<b> 24 seconds </b><br>Overall running times:<b> 3 minutes and 24 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.511 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4090 <ul></ul></li><li>Memory 23027 Mb <ul></ul></li><li>Clock 2610000 Khz <ul></ul></li><li>Processors 128 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900K <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65345 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1448490 Mb <ul></ul></li><li>Total disk space 1906794 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.511 |
00:03:25
55 |
95 |
32 |
23 |
e099f553533236e5e52ee7d1bd6d204d <h3>Benchmark Results</h3>SfM running times:<b> 55 seconds </b><br>MVS running times:<b> 95 seconds </b><br>Mesh running times:<b> 32 seconds </b><br>Texture running times:<b> 23 seconds </b><br>Overall running times:<b> 3 minutes and 25 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4090 <ul></ul></li><li>Memory 23027 Mb <ul></ul></li><li>Clock 2610000 Khz <ul></ul></li><li>Processors 128 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900K <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65345 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1076714 Mb <ul></ul></li><li>Total disk space 1906794 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:03:28
45 |
109 |
32 |
22 |
cd195e68e883fc92f61503cd2e914ae0 <h3>Benchmark Results</h3>SfM running times:<b> 45 seconds </b><br>MVS running times:<b> 109 seconds </b><br>Mesh running times:<b> 32 seconds </b><br>Texture running times:<b> 22 seconds </b><br>Overall running times:<b> 3 minutes and 28 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3080 Ti <ul></ul></li><li>Memory 12287 Mb <ul></ul></li><li>Clock 1710000 Khz <ul></ul></li><li>Processors 80 <ul></ul></li></ul><b>CPU </b><ul><li>Type Intel(R) Core(TM) i9-14900KF <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65362 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 451188 Mb <ul></ul></li><li>Total disk space 953253 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:03:31
38 |
114 |
35 |
24 |
158fb2dd5c9c2347f0e06e81c02601f5 <h3>Benchmark Results</h3>SfM running times:<b> 38 seconds </b><br>MVS running times:<b> 114 seconds </b><br>Mesh running times:<b> 35 seconds </b><br>Texture running times:<b> 24 seconds </b><br>Overall running times:<b> 3 minutes and 31 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3080 Ti <ul></ul></li><li>Memory 12287 Mb <ul></ul></li><li>Clock 1710000 Khz <ul></ul></li><li>Processors 80 <ul></ul></li></ul><b>CPU </b><ul><li>Type Intel(R) Core(TM) i9-14900KF <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65362 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 405468 Mb <ul></ul></li><li>Total disk space 953253 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:03:32
57 |
101 |
31 |
23 |
891395316a72767767cf543dd39ab28b <h3>Benchmark Results</h3>SfM running times:<b> 57 seconds </b><br>MVS running times:<b> 101 seconds </b><br>Mesh running times:<b> 31 seconds </b><br>Texture running times:<b> 23 seconds </b><br>Overall running times:<b> 3 minutes and 32 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.507 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4090 <ul></ul></li><li>Memory 23027 Mb <ul></ul></li><li>Clock 2610000 Khz <ul></ul></li><li>Processors 128 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900K <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65345 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1439121 Mb <ul></ul></li><li>Total disk space 1906794 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.507 |
00:03:32
59 |
99 |
31 |
23 |
ec5796fc5716cc500a70c095d9fafb59 <h3>Benchmark Results</h3>SfM running times:<b> 59 seconds </b><br>MVS running times:<b> 99 seconds </b><br>Mesh running times:<b> 31 seconds </b><br>Texture running times:<b> 23 seconds </b><br>Overall running times:<b> 3 minutes and 32 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.511 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4090 <ul></ul></li><li>Memory 23027 Mb <ul></ul></li><li>Clock 2610000 Khz <ul></ul></li><li>Processors 128 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900K <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65345 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1445994 Mb <ul></ul></li><li>Total disk space 1906794 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.511 |
00:03:33
52 |
104 |
33 |
24 |
63817fa06848c88abd9f0c3682ff4978 <h3>Benchmark Results</h3>SfM running times:<b> 52 seconds </b><br>MVS running times:<b> 104 seconds </b><br>Mesh running times:<b> 33 seconds </b><br>Texture running times:<b> 24 seconds </b><br>Overall running times:<b> 3 minutes and 33 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4090 <ul></ul></li><li>Memory 24563 Mb <ul></ul></li><li>Clock 2565000 Khz <ul></ul></li><li>Processors 128 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 9 7950X 16-Core Processor <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 31961 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 207151 Mb <ul></ul></li><li>Total disk space 952639 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:03:36
60 |
101 |
32 |
23 |
c4780840ffea74bb63fc5b947b85b378 <h3>Benchmark Results</h3>SfM running times:<b> 60 seconds </b><br>MVS running times:<b> 101 seconds </b><br>Mesh running times:<b> 32 seconds </b><br>Texture running times:<b> 23 seconds </b><br>Overall running times:<b> 3 minutes and 36 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.507 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4090 <ul></ul></li><li>Memory 23027 Mb <ul></ul></li><li>Clock 2610000 Khz <ul></ul></li><li>Processors 128 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900K <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65345 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1458405 Mb <ul></ul></li><li>Total disk space 1906794 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.507 |
00:03:38
48 |
113 |
34 |
23 |
be75bd4c8caa7ad66cc549ac5962c0d7 <h3>Benchmark Results</h3>SfM running times:<b> 48 seconds </b><br>MVS running times:<b> 113 seconds </b><br>Mesh running times:<b> 34 seconds </b><br>Texture running times:<b> 23 seconds </b><br>Overall running times:<b> 3 minutes and 38 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3080 Ti <ul></ul></li><li>Memory 12287 Mb <ul></ul></li><li>Clock 1710000 Khz <ul></ul></li><li>Processors 80 <ul></ul></li></ul><b>CPU </b><ul><li>Type Intel(R) Core(TM) i9-14900KF <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65362 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 451955 Mb <ul></ul></li><li>Total disk space 953253 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:03:40
49 |
116 |
31 |
24 |
ff6968826e1174547943c0890707c952 <h3>Benchmark Results</h3>SfM running times:<b> 49 seconds </b><br>MVS running times:<b> 116 seconds </b><br>Mesh running times:<b> 31 seconds </b><br>Texture running times:<b> 24 seconds </b><br>Overall running times:<b> 3 minutes and 40 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4070 <ul></ul></li><li>Memory 12281 Mb <ul></ul></li><li>Clock 2565000 Khz <ul></ul></li><li>Processors 46 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900KF <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65360 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1637306 Mb <ul></ul></li><li>Total disk space 1906415 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:03:41
57 |
102 |
39 |
23 |
50a6c064a7a7ec23b8732405d90d8de6 <h3>Benchmark Results</h3>SfM running times:<b> 57 seconds </b><br>MVS running times:<b> 102 seconds </b><br>Mesh running times:<b> 39 seconds </b><br>Texture running times:<b> 23 seconds </b><br>Overall running times:<b> 3 minutes and 41 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.501 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3090 <ul></ul></li><li>Memory 24575 Mb <ul></ul></li><li>Clock 1695000 Khz <ul></ul></li><li>Processors 82 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 9 7950X 16-Core Processor <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65259 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1119961 Mb <ul></ul></li><li>Total disk space 1907180 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.501 |
00:03:45
53 |
109 |
38 |
25 |
924375682a5d5e88dd7784fd2f78716a <h3>Benchmark Results</h3>SfM running times:<b> 53 seconds </b><br>MVS running times:<b> 109 seconds </b><br>Mesh running times:<b> 38 seconds </b><br>Texture running times:<b> 25 seconds </b><br>Overall running times:<b> 3 minutes and 45 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.511 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3060 <ul></ul></li><li>Memory 12287 Mb <ul></ul></li><li>Clock 1837000 Khz <ul></ul></li><li>Processors 28 <ul></ul></li></ul><b>CPU </b><ul><li>Type Intel(R) Core(TM) i5-14600K <ul></ul></li><li>Number of Cores 20 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32508 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 345969 Mb <ul></ul></li><li>Total disk space 487817 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.511 |
00:03:53
51 |
121 |
35 |
26 |
dce4e49c204ad86f645e3496ed5c1989 <h3>Benchmark Results</h3>SfM running times:<b> 51 seconds </b><br>MVS running times:<b> 121 seconds </b><br>Mesh running times:<b> 35 seconds </b><br>Texture running times:<b> 26 seconds </b><br>Overall running times:<b> 3 minutes and 53 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.505 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4080 <ul></ul></li><li>Memory 16375 Mb <ul></ul></li><li>Clock 2505000 Khz <ul></ul></li><li>Processors 76 <ul></ul></li></ul><b>CPU </b><ul><li>Type Intel(R) Core(TM) i5-14600K <ul></ul></li><li>Number of Cores 20 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65292 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 172019 Mb <ul></ul></li><li>Total disk space 409599 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.505 |
00:03:53
65 |
109 |
35 |
24 |
ca4c46baf881dcf3cdaf590aa6ba5ad8 <h3>Benchmark Results</h3>SfM running times:<b> 65 seconds </b><br>MVS running times:<b> 109 seconds </b><br>Mesh running times:<b> 35 seconds </b><br>Texture running times:<b> 24 seconds </b><br>Overall running times:<b> 3 minutes and 53 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.511 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3080 Ti <ul></ul></li><li>Memory 12287 Mb <ul></ul></li><li>Clock 1665000 Khz <ul></ul></li><li>Processors 80 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900K <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65101 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 226630 Mb <ul></ul></li><li>Total disk space 487737 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.511 |
00:03:55
54 |
125 |
32 |
24 |
33932251968233ce2d74ecabc1db7d07 <h3>Benchmark Results</h3>SfM running times:<b> 54 seconds </b><br>MVS running times:<b> 125 seconds </b><br>Mesh running times:<b> 32 seconds </b><br>Texture running times:<b> 24 seconds </b><br>Overall running times:<b> 3 minutes and 55 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.503 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4090 <ul></ul></li><li>Memory 24563 Mb <ul></ul></li><li>Clock 2520000 Khz <ul></ul></li><li>Processors 128 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900KF <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65254 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1553932 Mb <ul></ul></li><li>Total disk space 1931870 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.503 |
00:03:56
62 |
108 |
41 |
25 |
647450d8ee49c634de398800f59c2ea8 <h3>Benchmark Results</h3>SfM running times:<b> 62 seconds </b><br>MVS running times:<b> 108 seconds </b><br>Mesh running times:<b> 41 seconds </b><br>Texture running times:<b> 25 seconds </b><br>Overall running times:<b> 3 minutes and 56 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.409 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3090 <ul></ul></li><li>Memory 24575 Mb <ul></ul></li><li>Clock 1695000 Khz <ul></ul></li><li>Processors 82 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 9 7950X 16-Core Processor <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65259 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1563881 Mb <ul></ul></li><li>Total disk space 1907180 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.409 |
00:03:57
59 |
120 |
34 |
24 |
4b87031f39e864826fbb8d320e12d923 <h3>Benchmark Results</h3>SfM running times:<b> 59 seconds </b><br>MVS running times:<b> 120 seconds </b><br>Mesh running times:<b> 34 seconds </b><br>Texture running times:<b> 24 seconds </b><br>Overall running times:<b> 3 minutes and 57 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4070 Ti SUPER <ul></ul></li><li>Memory 16375 Mb <ul></ul></li><li>Clock 2640000 Khz <ul></ul></li><li>Processors 66 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 9 7950X3D 16-Core Processor <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 64631 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1603484 Mb <ul></ul></li><li>Total disk space 1906827 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:03:59
59 |
119 |
35 |
26 |
103d2be0599770771891894ce80c8430 <h3>Benchmark Results</h3>SfM running times:<b> 59 seconds </b><br>MVS running times:<b> 119 seconds </b><br>Mesh running times:<b> 35 seconds </b><br>Texture running times:<b> 26 seconds </b><br>Overall running times:<b> 3 minutes and 59 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4070 Ti SUPER <ul></ul></li><li>Memory 16375 Mb <ul></ul></li><li>Clock 2640000 Khz <ul></ul></li><li>Processors 66 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 9 7950X3D 16-Core Processor <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 64631 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1802612 Mb <ul></ul></li><li>Total disk space 1906827 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:04:02
62 |
118 |
37 |
25 |
a98f32df12bca123ab898689d90da1d1 <h3>Benchmark Results</h3>SfM running times:<b> 62 seconds </b><br>MVS running times:<b> 118 seconds </b><br>Mesh running times:<b> 37 seconds </b><br>Texture running times:<b> 25 seconds </b><br>Overall running times:<b> 4 minutes and 2 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.503 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 2060 SUPER <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1650000 Khz <ul></ul></li><li>Processors 34 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i5-13600K <ul></ul></li><li>Number of Cores 20 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32509 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 699644 Mb <ul></ul></li><li>Total disk space 952936 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.503 |
00:04:06
62 |
113 |
45 |
26 |
e8b47fc4d9a0c25ab21e9df5f631f6f7 <h3>Benchmark Results</h3>SfM running times:<b> 62 seconds </b><br>MVS running times:<b> 113 seconds </b><br>Mesh running times:<b> 45 seconds </b><br>Texture running times:<b> 26 seconds </b><br>Overall running times:<b> 4 minutes and 6 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.502 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3090 <ul></ul></li><li>Memory 24575 Mb <ul></ul></li><li>Clock 1695000 Khz <ul></ul></li><li>Processors 82 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 9 7950X 16-Core Processor <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 130189 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 878443 Mb <ul></ul></li><li>Total disk space 1907180 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.502 |
00:04:07
57 |
121 |
39 |
30 |
a8170c6832f166fe00e109aa984a13b1 <h3>Benchmark Results</h3>SfM running times:<b> 57 seconds </b><br>MVS running times:<b> 121 seconds </b><br>Mesh running times:<b> 39 seconds </b><br>Texture running times:<b> 30 seconds </b><br>Overall running times:<b> 4 minutes and 7 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.407 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3070 Ti <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1800000 Khz <ul></ul></li><li>Processors 48 <ul></ul></li></ul><b>CPU </b><ul><li>Type 11th Gen Intel(R) Core(TM) i9-11900 @ 2.50GHz <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65371 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 222110 Mb <ul></ul></li><li>Total disk space 446209 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.407 |
00:04:09
53 |
128 |
39 |
29 |
7837b51a580327bd5de887a0e1f6e957 <h3>Benchmark Results</h3>SfM running times:<b> 53 seconds </b><br>MVS running times:<b> 128 seconds </b><br>Mesh running times:<b> 39 seconds </b><br>Texture running times:<b> 29 seconds </b><br>Overall running times:<b> 4 minutes and 9 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.511 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4060 Ti <ul></ul></li><li>Memory 16379 Mb <ul></ul></li><li>Clock 2595000 Khz <ul></ul></li><li>Processors 34 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900KF <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 130920 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 607383 Mb <ul></ul></li><li>Total disk space 953181 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.511 |
00:04:15
46 |
148 |
37 |
24 |
ad0cf6825f0d16f681fe31874aa480aa <h3>Benchmark Results</h3>SfM running times:<b> 46 seconds </b><br>MVS running times:<b> 148 seconds </b><br>Mesh running times:<b> 37 seconds </b><br>Texture running times:<b> 24 seconds </b><br>Overall running times:<b> 4 minutes and 15 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.503 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3060 <ul></ul></li><li>Memory 12287 Mb <ul></ul></li><li>Clock 1837000 Khz <ul></ul></li><li>Processors 28 <ul></ul></li></ul><b>CPU </b><ul><li>Type Intel(R) Core(TM) i9-14900K <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 196371 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1762364 Mb <ul></ul></li><li>Total disk space 1906921 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.503 |
00:04:17
53 |
142 |
38 |
24 |
2f67eb7b709143e5ab0ac5eb7d12617c <h3>Benchmark Results</h3>SfM running times:<b> 53 seconds </b><br>MVS running times:<b> 142 seconds </b><br>Mesh running times:<b> 38 seconds </b><br>Texture running times:<b> 24 seconds </b><br>Overall running times:<b> 4 minutes and 17 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.405 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3060 Ti <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1665000 Khz <ul></ul></li><li>Processors 38 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i7-13700K <ul></ul></li><li>Number of Cores 24 <ul></ul></li></ul><b>RAM </b><ul><li>Total 130834 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 57104 Mb <ul></ul></li><li>Total disk space 299245 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.405 |
00:04:20
67 |
124 |
38 |
31 |
82f2b981546f85dbfc5b880e9d5db946 <h3>Benchmark Results</h3>SfM running times:<b> 67 seconds </b><br>MVS running times:<b> 124 seconds </b><br>Mesh running times:<b> 38 seconds </b><br>Texture running times:<b> 31 seconds </b><br>Overall running times:<b> 4 minutes and 20 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3090 <ul></ul></li><li>Memory 24575 Mb <ul></ul></li><li>Clock 1725000 Khz <ul></ul></li><li>Processors 82 <ul></ul></li></ul><b>CPU </b><ul><li>Type 12th Gen Intel(R) Core(TM) i9-12900KF <ul></ul></li><li>Number of Cores 24 <ul></ul></li></ul><b>RAM </b><ul><li>Total 130916 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1304923 Mb <ul></ul></li><li>Total disk space 1906723 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:04:21
73 |
120 |
38 |
30 |
8cbc446e6247c59bdb260b29b04f5b29 <h3>Benchmark Results</h3>SfM running times:<b> 73 seconds </b><br>MVS running times:<b> 120 seconds </b><br>Mesh running times:<b> 38 seconds </b><br>Texture running times:<b> 30 seconds </b><br>Overall running times:<b> 4 minutes and 21 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.405 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3070 Ti <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1800000 Khz <ul></ul></li><li>Processors 48 <ul></ul></li></ul><b>CPU </b><ul><li>Type 11th Gen Intel(R) Core(TM) i9-11900 @ 2.50GHz <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65371 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 225332 Mb <ul></ul></li><li>Total disk space 446209 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.405 |
00:04:21
73 |
119 |
39 |
30 |
84eb907809126d4057ec42021840204e <h3>Benchmark Results</h3>SfM running times:<b> 73 seconds </b><br>MVS running times:<b> 119 seconds </b><br>Mesh running times:<b> 39 seconds </b><br>Texture running times:<b> 30 seconds </b><br>Overall running times:<b> 4 minutes and 21 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.410 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3070 Ti <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1800000 Khz <ul></ul></li><li>Processors 48 <ul></ul></li></ul><b>CPU </b><ul><li>Type 11th Gen Intel(R) Core(TM) i9-11900 @ 2.50GHz <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65371 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 219046 Mb <ul></ul></li><li>Total disk space 446209 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.410 |
00:04:25
74 |
122 |
39 |
30 |
b3ac7de952d6c44fac167a00d468fc71 <h3>Benchmark Results</h3>SfM running times:<b> 74 seconds </b><br>MVS running times:<b> 122 seconds </b><br>Mesh running times:<b> 39 seconds </b><br>Texture running times:<b> 30 seconds </b><br>Overall running times:<b> 4 minutes and 25 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.406 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3070 Ti <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1800000 Khz <ul></ul></li><li>Processors 48 <ul></ul></li></ul><b>CPU </b><ul><li>Type 11th Gen Intel(R) Core(TM) i9-11900 @ 2.50GHz <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65371 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 223489 Mb <ul></ul></li><li>Total disk space 446209 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.406 |
00:04:29
68 |
123 |
49 |
29 |
7084c189ee7c3526ac41245d6183f0ab <h3>Benchmark Results</h3>SfM running times:<b> 68 seconds </b><br>MVS running times:<b> 123 seconds </b><br>Mesh running times:<b> 49 seconds </b><br>Texture running times:<b> 29 seconds </b><br>Overall running times:<b> 4 minutes and 29 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.502 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3090 <ul></ul></li><li>Memory 24575 Mb <ul></ul></li><li>Clock 1695000 Khz <ul></ul></li><li>Processors 82 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 9 7950X 16-Core Processor <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 130189 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 882428 Mb <ul></ul></li><li>Total disk space 1907180 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.502 |
00:04:33
84 |
121 |
38 |
30 |
cea1f8374fca5fda071935b197ecd304 <h3>Benchmark Results</h3>SfM running times:<b> 84 seconds </b><br>MVS running times:<b> 121 seconds </b><br>Mesh running times:<b> 38 seconds </b><br>Texture running times:<b> 30 seconds </b><br>Overall running times:<b> 4 minutes and 33 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.408 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3070 Ti <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1800000 Khz <ul></ul></li><li>Processors 48 <ul></ul></li></ul><b>CPU </b><ul><li>Type 11th Gen Intel(R) Core(TM) i9-11900 @ 2.50GHz <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65371 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 221400 Mb <ul></ul></li><li>Total disk space 446209 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.408 |
00:04:35
74 |
127 |
44 |
30 |
191646e0198af5951216570ebc729f22 <h3>Benchmark Results</h3>SfM running times:<b> 74 seconds </b><br>MVS running times:<b> 127 seconds </b><br>Mesh running times:<b> 44 seconds </b><br>Texture running times:<b> 30 seconds </b><br>Overall running times:<b> 4 minutes and 35 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.503 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3070 Ti <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1800000 Khz <ul></ul></li><li>Processors 48 <ul></ul></li></ul><b>CPU </b><ul><li>Type 11th Gen Intel(R) Core(TM) i9-11900 @ 2.50GHz <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65371 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 241103 Mb <ul></ul></li><li>Total disk space 446209 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.503 |
00:04:36
81 |
127 |
37 |
31 |
83af6a033dac26c775c052fe79cc079b <h3>Benchmark Results</h3>SfM running times:<b> 81 seconds </b><br>MVS running times:<b> 127 seconds </b><br>Mesh running times:<b> 37 seconds </b><br>Texture running times:<b> 31 seconds </b><br>Overall running times:<b> 4 minutes and 36 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.511 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4080 <ul></ul></li><li>Memory 16375 Mb <ul></ul></li><li>Clock 2610000 Khz <ul></ul></li><li>Processors 76 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 7 5800X3D 8-Core Processor <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 49061 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 71562 Mb <ul></ul></li><li>Total disk space 236341 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.511 |
00:04:37
77 |
127 |
38 |
35 |
55cb93ccd5c6e1ce38a6df8c4f91f638 <h3>Benchmark Results</h3>SfM running times:<b> 77 seconds </b><br>MVS running times:<b> 127 seconds </b><br>Mesh running times:<b> 38 seconds </b><br>Texture running times:<b> 35 seconds </b><br>Overall running times:<b> 4 minutes and 37 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.501 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4090 <ul></ul></li><li>Memory 24563 Mb <ul></ul></li><li>Clock 2625000 Khz <ul></ul></li><li>Processors 128 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 7 5800X3D 8-Core Processor <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32679 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 278704 Mb <ul></ul></li><li>Total disk space 476180 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.501 |
00:04:40
64 |
149 |
38 |
29 |
49a42643288c7b43f3bcccec83bb38a3 <h3>Benchmark Results</h3>SfM running times:<b> 64 seconds </b><br>MVS running times:<b> 149 seconds </b><br>Mesh running times:<b> 38 seconds </b><br>Texture running times:<b> 29 seconds </b><br>Overall running times:<b> 4 minutes and 40 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4080 Laptop GPU <ul></ul></li><li>Memory 12281 Mb <ul></ul></li><li>Clock 2010000 Khz <ul></ul></li><li>Processors 58 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i7-13700H <ul></ul></li><li>Number of Cores 20 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65263 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 708894 Mb <ul></ul></li><li>Total disk space 954429 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:04:44
54 |
138 |
51 |
41 |
19e9903429ecf630953bccb59f4ac4be <h3>Benchmark Results</h3>SfM running times:<b> 54 seconds </b><br>MVS running times:<b> 138 seconds </b><br>Mesh running times:<b> 51 seconds </b><br>Texture running times:<b> 41 seconds </b><br>Overall running times:<b> 4 minutes and 44 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA RTX A4000 <ul></ul></li><li>Memory 16375 Mb <ul></ul></li><li>Clock 1560000 Khz <ul></ul></li><li>Processors 48 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900K <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65224 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 303709 Mb <ul></ul></li><li>Total disk space 975432 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:04:49
80 |
142 |
37 |
30 |
efe6f07bf4f9c25057d4c1822b80055b <h3>Benchmark Results</h3>SfM running times:<b> 80 seconds </b><br>MVS running times:<b> 142 seconds </b><br>Mesh running times:<b> 37 seconds </b><br>Texture running times:<b> 30 seconds </b><br>Overall running times:<b> 4 minutes and 49 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.511 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4070 Laptop GPU <ul></ul></li><li>Memory 8187 Mb <ul></ul></li><li>Clock 2175000 Khz <ul></ul></li><li>Processors 36 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900H <ul></ul></li><li>Number of Cores 20 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32397 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 839647 Mb <ul></ul></li><li>Total disk space 948750 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.511 |
00:04:51
89 |
131 |
41 |
30 |
e1e6957f5ef2ded5955de94f6033ca09 <h3>Benchmark Results</h3>SfM running times:<b> 89 seconds </b><br>MVS running times:<b> 131 seconds </b><br>Mesh running times:<b> 41 seconds </b><br>Texture running times:<b> 30 seconds </b><br>Overall running times:<b> 4 minutes and 51 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.405 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 2080 Ti <ul></ul></li><li>Memory 11263 Mb <ul></ul></li><li>Clock 1650000 Khz <ul></ul></li><li>Processors 68 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 9 5900X 12-Core Processor <ul></ul></li><li>Number of Cores 24 <ul></ul></li></ul><b>RAM </b><ul><li>Total 130980 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: F: <ul></ul></li><li>Available disk space 2400636 Mb <ul></ul></li><li>Total disk space 3813318 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.405 |
00:04:58
80 |
135 |
49 |
34 |
8d2aa556c146312b7a7df26cdb319637 <h3>Benchmark Results</h3>SfM running times:<b> 80 seconds </b><br>MVS running times:<b> 135 seconds </b><br>Mesh running times:<b> 49 seconds </b><br>Texture running times:<b> 34 seconds </b><br>Overall running times:<b> 4 minutes and 58 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.507 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3080 Laptop GPU <ul></ul></li><li>Memory 16383 Mb <ul></ul></li><li>Clock 1365000 Khz <ul></ul></li><li>Processors 48 <ul></ul></li></ul><b>CPU </b><ul><li>Type 11th Gen Intel(R) Core(TM) i9-11900H @ 2.50GHz <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32583 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 540501 Mb <ul></ul></li><li>Total disk space 956944 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.507 |
00:05:01
81 |
136 |
50 |
34 |
f0979dd9569ebbfd0ce6ded2c4a9a3a3 <h3>Benchmark Results</h3>SfM running times:<b> 81 seconds </b><br>MVS running times:<b> 136 seconds </b><br>Mesh running times:<b> 50 seconds </b><br>Texture running times:<b> 34 seconds </b><br>Overall running times:<b> 5 minutes and 1 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.507 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3080 Laptop GPU <ul></ul></li><li>Memory 16383 Mb <ul></ul></li><li>Clock 1365000 Khz <ul></ul></li><li>Processors 48 <ul></ul></li></ul><b>CPU </b><ul><li>Type 11th Gen Intel(R) Core(TM) i9-11900H @ 2.50GHz <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32583 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 540374 Mb <ul></ul></li><li>Total disk space 956944 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.507 |
00:05:02
81 |
136 |
49 |
36 |
d4690131e11670ab2e8fb7b884eb1051 <h3>Benchmark Results</h3>SfM running times:<b> 81 seconds </b><br>MVS running times:<b> 136 seconds </b><br>Mesh running times:<b> 49 seconds </b><br>Texture running times:<b> 36 seconds </b><br>Overall running times:<b> 5 minutes and 2 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3080 Laptop GPU <ul></ul></li><li>Memory 16383 Mb <ul></ul></li><li>Clock 1365000 Khz <ul></ul></li><li>Processors 48 <ul></ul></li></ul><b>CPU </b><ul><li>Type 11th Gen Intel(R) Core(TM) i9-11900H @ 2.50GHz <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32583 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 532547 Mb <ul></ul></li><li>Total disk space 956944 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:05:04
80 |
138 |
51 |
35 |
ce0af32702f86257525def0b324921a0 <h3>Benchmark Results</h3>SfM running times:<b> 80 seconds </b><br>MVS running times:<b> 138 seconds </b><br>Mesh running times:<b> 51 seconds </b><br>Texture running times:<b> 35 seconds </b><br>Overall running times:<b> 5 minutes and 4 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.502 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3080 Laptop GPU <ul></ul></li><li>Memory 16383 Mb <ul></ul></li><li>Clock 1365000 Khz <ul></ul></li><li>Processors 48 <ul></ul></li></ul><b>CPU </b><ul><li>Type 11th Gen Intel(R) Core(TM) i9-11900H @ 2.50GHz <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32583 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 539523 Mb <ul></ul></li><li>Total disk space 956944 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.502 |
00:05:04
82 |
132 |
42 |
48 |
e157add100b3322a292bcba74c0196e5 <h3>Benchmark Results</h3>SfM running times:<b> 82 seconds </b><br>MVS running times:<b> 132 seconds </b><br>Mesh running times:<b> 42 seconds </b><br>Texture running times:<b> 48 seconds </b><br>Overall running times:<b> 5 minutes and 4 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3080 <ul></ul></li><li>Memory 10239 Mb <ul></ul></li><li>Clock 1710000 Khz <ul></ul></li><li>Processors 68 <ul></ul></li></ul><b>CPU </b><ul><li>Type 12th Gen Intel(R) Core(TM) i7-12700 <ul></ul></li><li>Number of Cores 20 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32509 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 459234 Mb <ul></ul></li><li>Total disk space 976118 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:05:07
61 |
179 |
38 |
29 |
fe6586b7a2ec4d6265ccc3d356bd3e83 <h3>Benchmark Results</h3>SfM running times:<b> 61 seconds </b><br>MVS running times:<b> 179 seconds </b><br>Mesh running times:<b> 38 seconds </b><br>Texture running times:<b> 29 seconds </b><br>Overall running times:<b> 5 minutes and 7 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.404 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3060 Ti <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1665000 Khz <ul></ul></li><li>Processors 38 <ul></ul></li></ul><b>CPU </b><ul><li>Type 12th Gen Intel(R) Core(TM) i7-12700K <ul></ul></li><li>Number of Cores 20 <ul></ul></li></ul><b>RAM </b><ul><li>Total 130859 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 29322 Mb <ul></ul></li><li>Total disk space 475276 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.404 |
00:05:15
81 |
136 |
51 |
47 |
6c39630b99b78ca49a2ea030788a2abf <h3>Benchmark Results</h3>SfM running times:<b> 81 seconds </b><br>MVS running times:<b> 136 seconds </b><br>Mesh running times:<b> 51 seconds </b><br>Texture running times:<b> 47 seconds </b><br>Overall running times:<b> 5 minutes and 15 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.502 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4080 <ul></ul></li><li>Memory 16375 Mb <ul></ul></li><li>Clock 2505000 Khz <ul></ul></li><li>Processors 76 <ul></ul></li></ul><b>CPU </b><ul><li>Type Intel(R) Core(TM) i5-8600K CPU @ 3.60GHz <ul></ul></li><li>Number of Cores 6 <ul></ul></li></ul><b>RAM </b><ul><li>Total 16333 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 54237 Mb <ul></ul></li><li>Total disk space 255999 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.502 |
00:05:15
69 |
144 |
59 |
43 |
5e193929fc3ebf18e28b0ed9210e3de1 <h3>Benchmark Results</h3>SfM running times:<b> 69 seconds </b><br>MVS running times:<b> 144 seconds </b><br>Mesh running times:<b> 59 seconds </b><br>Texture running times:<b> 43 seconds </b><br>Overall running times:<b> 5 minutes and 15 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce GTX 1080 Ti <ul></ul></li><li>Memory 11263 Mb <ul></ul></li><li>Clock 1683000 Khz <ul></ul></li><li>Processors 28 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 7 3700X 8-Core Processor <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32695 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1008110 Mb <ul></ul></li><li>Total disk space 1952239 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:05:18
68 |
175 |
44 |
31 |
e08cad69c7ee632f76611a8ac0720d2f <h3>Benchmark Results</h3>SfM running times:<b> 68 seconds </b><br>MVS running times:<b> 175 seconds </b><br>Mesh running times:<b> 44 seconds </b><br>Texture running times:<b> 31 seconds </b><br>Overall running times:<b> 5 minutes and 18 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3060 Ti <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1710000 Khz <ul></ul></li><li>Processors 38 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 9 5900X 12-Core Processor <ul></ul></li><li>Number of Cores 24 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32692 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 477 Mb <ul></ul></li><li>Total disk space 81040 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:05:20
86 |
149 |
49 |
36 |
ef5b6cbc8fbd25cc6a6b49b45bbac7a3 <h3>Benchmark Results</h3>SfM running times:<b> 86 seconds </b><br>MVS running times:<b> 149 seconds </b><br>Mesh running times:<b> 49 seconds </b><br>Texture running times:<b> 36 seconds </b><br>Overall running times:<b> 5 minutes and 20 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.502 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3070 Ti Laptop GPU <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1035000 Khz <ul></ul></li><li>Processors 46 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 9 6900HS with Radeon Graphics <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32012 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 571108 Mb <ul></ul></li><li>Total disk space 975474 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.502 |
00:05:20
81 |
152 |
53 |
34 |
2fbeaca2fa3372bf160d60d0f74d03de <h3>Benchmark Results</h3>SfM running times:<b> 81 seconds </b><br>MVS running times:<b> 152 seconds </b><br>Mesh running times:<b> 53 seconds </b><br>Texture running times:<b> 34 seconds </b><br>Overall running times:<b> 5 minutes and 20 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.507 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce GTX 1080 <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1759000 Khz <ul></ul></li><li>Processors 20 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 9 5900X 12-Core Processor <ul></ul></li><li>Number of Cores 24 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65446 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 79740 Mb <ul></ul></li><li>Total disk space 476324 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.507 |
00:05:21
98 |
138 |
50 |
35 |
9009ea545ef73612fb4eb00c62a6f503 <h3>Benchmark Results</h3>SfM running times:<b> 98 seconds </b><br>MVS running times:<b> 138 seconds </b><br>Mesh running times:<b> 50 seconds </b><br>Texture running times:<b> 35 seconds </b><br>Overall running times:<b> 5 minutes and 21 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3080 Laptop GPU <ul></ul></li><li>Memory 16383 Mb <ul></ul></li><li>Clock 1365000 Khz <ul></ul></li><li>Processors 48 <ul></ul></li></ul><b>CPU </b><ul><li>Type 11th Gen Intel(R) Core(TM) i9-11900H @ 2.50GHz <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32583 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 524689 Mb <ul></ul></li><li>Total disk space 956944 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:05:23
68 |
162 |
51 |
42 |
8c7bf89533f6c941bd2dd1af5c276319 <h3>Benchmark Results</h3>SfM running times:<b> 68 seconds </b><br>MVS running times:<b> 162 seconds </b><br>Mesh running times:<b> 51 seconds </b><br>Texture running times:<b> 42 seconds </b><br>Overall running times:<b> 5 minutes and 23 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.402 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 2070 SUPER <ul></ul></li><li>Memory 8192 Mb <ul></ul></li><li>Clock 1800000 Khz <ul></ul></li><li>Processors 40 <ul></ul></li></ul><b>CPU </b><ul><li>Type Intel(R) Core(TM) i7-9700 CPU @ 3.00GHz <ul></ul></li><li>Number of Cores 8 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65438 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 117440 Mb <ul></ul></li><li>Total disk space 487740 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.402 |
00:05:23
79 |
136 |
53 |
55 |
d0d1e9356800f24d8db772a685e348dc <h3>Benchmark Results</h3>SfM running times:<b> 79 seconds </b><br>MVS running times:<b> 136 seconds </b><br>Mesh running times:<b> 53 seconds </b><br>Texture running times:<b> 55 seconds </b><br>Overall running times:<b> 5 minutes and 23 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.507 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4060 <ul></ul></li><li>Memory 8187 Mb <ul></ul></li><li>Clock 2490000 Khz <ul></ul></li><li>Processors 24 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 7 5700G with Radeon Graphics <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 28565 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 90627 Mb <ul></ul></li><li>Total disk space 199999 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.507 |
00:05:27
83 |
138 |
70 |
36 |
a598db492dda747c19af487919aed85c <h3>Benchmark Results</h3>SfM running times:<b> 83 seconds </b><br>MVS running times:<b> 138 seconds </b><br>Mesh running times:<b> 70 seconds </b><br>Texture running times:<b> 36 seconds </b><br>Overall running times:<b> 5 minutes and 27 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA RTX A1000 6GB Laptop GPU <ul></ul></li><li>Memory 6143 Mb <ul></ul></li><li>Clock 1297000 Khz <ul></ul></li><li>Processors 20 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i7-13700H <ul></ul></li><li>Number of Cores 20 <ul></ul></li></ul><b>RAM </b><ul><li>Total 16068 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 335755 Mb <ul></ul></li><li>Total disk space 485502 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:05:28
69 |
185 |
41 |
33 |
fc1d38994a45ccf4c1eaafcabb910263 <h3>Benchmark Results</h3>SfM running times:<b> 69 seconds </b><br>MVS running times:<b> 185 seconds </b><br>Mesh running times:<b> 41 seconds </b><br>Texture running times:<b> 33 seconds </b><br>Overall running times:<b> 5 minutes and 28 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.405 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3080 <ul></ul></li><li>Memory 12287 Mb <ul></ul></li><li>Clock 1710000 Khz <ul></ul></li><li>Processors 70 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 9 5900X 12-Core Processor <ul></ul></li><li>Number of Cores 24 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65461 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 328737 Mb <ul></ul></li><li>Total disk space 476210 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.405 |
00:05:29
70 |
188 |
42 |
29 |
d876e9e7af5c067b8687392a64d3159c <h3>Benchmark Results</h3>SfM running times:<b> 70 seconds </b><br>MVS running times:<b> 188 seconds </b><br>Mesh running times:<b> 42 seconds </b><br>Texture running times:<b> 29 seconds </b><br>Overall running times:<b> 5 minutes and 29 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.405 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4090 <ul></ul></li><li>Memory 24563 Mb <ul></ul></li><li>Clock 2565000 Khz <ul></ul></li><li>Processors 128 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen Threadripper PRO 5965WX 24-Cores <ul></ul></li><li>Number of Cores 48 <ul></ul></li></ul><b>RAM </b><ul><li>Total 524127 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 2628402 Mb <ul></ul></li><li>Total disk space 3814654 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.405 |
00:05:31
95 |
150 |
50 |
36 |
0387ffc7a045dab1a589502a289532a6 <h3>Benchmark Results</h3>SfM running times:<b> 95 seconds </b><br>MVS running times:<b> 150 seconds </b><br>Mesh running times:<b> 50 seconds </b><br>Texture running times:<b> 36 seconds </b><br>Overall running times:<b> 5 minutes and 31 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4060 Ti <ul></ul></li><li>Memory 16379 Mb <ul></ul></li><li>Clock 2535000 Khz <ul></ul></li><li>Processors 34 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 5 5600 6-Core Processor <ul></ul></li><li>Number of Cores 12 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32672 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1393389 Mb <ul></ul></li><li>Total disk space 1906952 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:05:36
107 |
127 |
55 |
47 |
13df22d26ffb57ebe3a38b34f5e1e887 <h3>Benchmark Results</h3>SfM running times:<b> 107 seconds </b><br>MVS running times:<b> 127 seconds </b><br>Mesh running times:<b> 55 seconds </b><br>Texture running times:<b> 47 seconds </b><br>Overall running times:<b> 5 minutes and 36 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.409 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3060 <ul></ul></li><li>Memory 12287 Mb <ul></ul></li><li>Clock 1852000 Khz <ul></ul></li><li>Processors 28 <ul></ul></li></ul><b>GPU #2 </b><ul><li>Type NVIDIA GeForce GTX 1060 6GB <ul></ul></li><li>Memory 6143 Mb <ul></ul></li><li>Clock 1708500 Khz <ul></ul></li><li>Processors 10 <ul></ul></li></ul><b>CPU </b><ul><li>Type Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz <ul></ul></li><li>Number of Cores 12 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65471 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 778862 Mb <ul></ul></li><li>Total disk space 952776 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.409 |
00:05:36
99 |
166 |
44 |
27 |
34570fb9e9335b5badfea7ccb1e1aca9 <h3>Benchmark Results</h3>SfM running times:<b> 99 seconds </b><br>MVS running times:<b> 166 seconds </b><br>Mesh running times:<b> 44 seconds </b><br>Texture running times:<b> 27 seconds </b><br>Overall running times:<b> 5 minutes and 36 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.507 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4070 Ti <ul></ul></li><li>Memory 12281 Mb <ul></ul></li><li>Clock 2610000 Khz <ul></ul></li><li>Processors 60 <ul></ul></li></ul><b>CPU </b><ul><li>Type 13th Gen Intel(R) Core(TM) i9-13900 <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32418 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 812149 Mb <ul></ul></li><li>Total disk space 950838 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.507 |
00:05:38
85 |
171 |
46 |
36 |
748d3078d98760b8dc75ea69c61a4c76 <h3>Benchmark Results</h3>SfM running times:<b> 85 seconds </b><br>MVS running times:<b> 171 seconds </b><br>Mesh running times:<b> 46 seconds </b><br>Texture running times:<b> 36 seconds </b><br>Overall running times:<b> 5 minutes and 38 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.502 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3090 Ti <ul></ul></li><li>Memory 24563 Mb <ul></ul></li><li>Clock 1920000 Khz <ul></ul></li><li>Processors 84 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen Threadripper PRO 5995WX 64-Cores <ul></ul></li><li>Number of Cores 64 <ul></ul></li></ul><b>RAM </b><ul><li>Total 261970 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1361267 Mb <ul></ul></li><li>Total disk space 1952721 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.502 |
00:05:38
87 |
151 |
56 |
44 |
5cb06925dcf93f080d469727be90c604 <h3>Benchmark Results</h3>SfM running times:<b> 87 seconds </b><br>MVS running times:<b> 151 seconds </b><br>Mesh running times:<b> 56 seconds </b><br>Texture running times:<b> 44 seconds </b><br>Overall running times:<b> 5 minutes and 38 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.511 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3060 <ul></ul></li><li>Memory 12287 Mb <ul></ul></li><li>Clock 1807000 Khz <ul></ul></li><li>Processors 28 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 5 3600 6-Core Processor <ul></ul></li><li>Number of Cores 12 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32687 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 859200 Mb <ul></ul></li><li>Total disk space 953196 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.511 |
00:05:39
95 |
144 |
60 |
40 |
e6501369ffbd80ca628545d0ab048927 <h3>Benchmark Results</h3>SfM running times:<b> 95 seconds </b><br>MVS running times:<b> 144 seconds </b><br>Mesh running times:<b> 60 seconds </b><br>Texture running times:<b> 40 seconds </b><br>Overall running times:<b> 5 minutes and 39 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.507 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3050 <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1807000 Khz <ul></ul></li><li>Processors 20 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 7 5700G with Radeon Graphics <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65383 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 312845 Mb <ul></ul></li><li>Total disk space 487642 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.507 |
00:05:41
119 |
129 |
50 |
43 |
a9835a09659a16c0f83a3182a784bb2d <h3>Benchmark Results</h3>SfM running times:<b> 119 seconds </b><br>MVS running times:<b> 129 seconds </b><br>Mesh running times:<b> 50 seconds </b><br>Texture running times:<b> 43 seconds </b><br>Overall running times:<b> 5 minutes and 41 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.405 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3060 <ul></ul></li><li>Memory 12287 Mb <ul></ul></li><li>Clock 1852000 Khz <ul></ul></li><li>Processors 28 <ul></ul></li></ul><b>GPU #2 </b><ul><li>Type NVIDIA GeForce GTX 1060 6GB <ul></ul></li><li>Memory 6143 Mb <ul></ul></li><li>Clock 1708500 Khz <ul></ul></li><li>Processors 10 <ul></ul></li></ul><b>CPU </b><ul><li>Type Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz <ul></ul></li><li>Number of Cores 12 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65471 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 37170 Mb <ul></ul></li><li>Total disk space 237380 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.405 |
00:05:42
97 |
148 |
55 |
42 |
491e6328528944ee12bf35cca59caa34 <h3>Benchmark Results</h3>SfM running times:<b> 97 seconds </b><br>MVS running times:<b> 148 seconds </b><br>Mesh running times:<b> 55 seconds </b><br>Texture running times:<b> 42 seconds </b><br>Overall running times:<b> 5 minutes and 42 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.511 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3060 <ul></ul></li><li>Memory 12287 Mb <ul></ul></li><li>Clock 1807000 Khz <ul></ul></li><li>Processors 28 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 5 3600 6-Core Processor <ul></ul></li><li>Number of Cores 12 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32687 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 860022 Mb <ul></ul></li><li>Total disk space 953196 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.511 |
00:05:45
72 |
159 |
67 |
47 |
66f7e5938efbe069b5f60ec1a807533c <h3>Benchmark Results</h3>SfM running times:<b> 72 seconds </b><br>MVS running times:<b> 159 seconds </b><br>Mesh running times:<b> 67 seconds </b><br>Texture running times:<b> 47 seconds </b><br>Overall running times:<b> 5 minutes and 45 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.511 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3060 <ul></ul></li><li>Memory 12287 Mb <ul></ul></li><li>Clock 1837000 Khz <ul></ul></li><li>Processors 28 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 9 3900X 12-Core Processor <ul></ul></li><li>Number of Cores 24 <ul></ul></li></ul><b>RAM </b><ul><li>Total 130987 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: D: <ul></ul></li><li>Available disk space 266242 Mb <ul></ul></li><li>Total disk space 953866 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.511 |
00:05:45
85 |
116 |
117 |
27 |
92422eab363348f6d30ebd92435869e3 <h3>Benchmark Results</h3>SfM running times:<b> 85 seconds </b><br>MVS running times:<b> 116 seconds </b><br>Mesh running times:<b> 117 seconds </b><br>Texture running times:<b> 27 seconds </b><br>Overall running times:<b> 5 minutes and 45 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>No Cuda GPU Found </b><ul></ul><b>CPU </b><ul><li>Type AMD Ryzen 9 7900 12-Core Processor <ul></ul></li><li>Number of Cores 24 <ul></ul></li></ul><b>RAM </b><ul><li>Total 31892 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 609213 Mb <ul></ul></li><li>Total disk space 953061 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:05:46
86 |
114 |
120 |
26 |
8656964c4b4d800a8a04b62c7b2cb080 <h3>Benchmark Results</h3>SfM running times:<b> 86 seconds </b><br>MVS running times:<b> 114 seconds </b><br>Mesh running times:<b> 120 seconds </b><br>Texture running times:<b> 26 seconds </b><br>Overall running times:<b> 5 minutes and 46 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.503 <ul></ul></li></ul><b>No Cuda GPU Found </b><ul></ul><b>CPU </b><ul><li>Type AMD Ryzen 9 7900 12-Core Processor <ul></ul></li><li>Number of Cores 24 <ul></ul></li></ul><b>RAM </b><ul><li>Total 31892 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1190995 Mb <ul></ul></li><li>Total disk space 1953396 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.503 |
00:05:46
89 |
150 |
60 |
47 |
f4ff5f768b3327ef0638afafb2e9352c <h3>Benchmark Results</h3>SfM running times:<b> 89 seconds </b><br>MVS running times:<b> 150 seconds </b><br>Mesh running times:<b> 60 seconds </b><br>Texture running times:<b> 47 seconds </b><br>Overall running times:<b> 5 minutes and 46 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.511 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 2060 <ul></ul></li><li>Memory 6143 Mb <ul></ul></li><li>Clock 1680000 Khz <ul></ul></li><li>Processors 30 <ul></ul></li></ul><b>CPU </b><ul><li>Type Intel(R) Core(TM) i7-9700 CPU @ 3.00GHz <ul></ul></li><li>Number of Cores 8 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32684 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 69899 Mb <ul></ul></li><li>Total disk space 243048 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.511 |
00:05:47
84 |
142 |
61 |
60 |
8cb4c9622027a679406b3b3e06c42028 <h3>Benchmark Results</h3>SfM running times:<b> 84 seconds </b><br>MVS running times:<b> 142 seconds </b><br>Mesh running times:<b> 61 seconds </b><br>Texture running times:<b> 60 seconds </b><br>Overall running times:<b> 5 minutes and 47 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.507 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce GTX 1070 <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1784500 Khz <ul></ul></li><li>Processors 15 <ul></ul></li></ul><b>CPU </b><ul><li>Type 11th Gen Intel(R) Core(TM) i5-11500 @ 2.70GHz <ul></ul></li><li>Number of Cores 12 <ul></ul></li></ul><b>RAM </b><ul><li>Total 16241 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 239410 Mb <ul></ul></li><li>Total disk space 476284 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.507 |
00:05:49
97 |
157 |
56 |
39 |
859c815384712c9c85650bb6eb308996 <h3>Benchmark Results</h3>SfM running times:<b> 97 seconds </b><br>MVS running times:<b> 157 seconds </b><br>Mesh running times:<b> 56 seconds </b><br>Texture running times:<b> 39 seconds </b><br>Overall running times:<b> 5 minutes and 49 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3070 <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1815000 Khz <ul></ul></li><li>Processors 46 <ul></ul></li></ul><b>CPU </b><ul><li>Type Intel(R) Core(TM) i7-10700KF CPU @ 3.80GHz <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32660 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 64019 Mb <ul></ul></li><li>Total disk space 476323 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:05:50
99 |
156 |
51 |
44 |
1edf5677ba21882a764d5b920d8462e0 <h3>Benchmark Results</h3>SfM running times:<b> 99 seconds </b><br>MVS running times:<b> 156 seconds </b><br>Mesh running times:<b> 51 seconds </b><br>Texture running times:<b> 44 seconds </b><br>Overall running times:<b> 5 minutes and 50 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.405 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 2080 SUPER <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1845000 Khz <ul></ul></li><li>Processors 48 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 7 3700X 8-Core Processor <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32689 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 173007 Mb <ul></ul></li><li>Total disk space 952718 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.405 |
00:05:50
96 |
164 |
53 |
37 |
48e0a48acbeb710498c8c782c7ec3da7 <h3>Benchmark Results</h3>SfM running times:<b> 96 seconds </b><br>MVS running times:<b> 164 seconds </b><br>Mesh running times:<b> 53 seconds </b><br>Texture running times:<b> 37 seconds </b><br>Overall running times:<b> 5 minutes and 50 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.507 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3080 Laptop GPU <ul></ul></li><li>Memory 16383 Mb <ul></ul></li><li>Clock 1605000 Khz <ul></ul></li><li>Processors 48 <ul></ul></li></ul><b>CPU </b><ul><li>Type 11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32509 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 396917 Mb <ul></ul></li><li>Total disk space 953176 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.507 |
00:05:52
88 |
147 |
56 |
61 |
8a65d21a4749259c098e9765bd786bcd <h3>Benchmark Results</h3>SfM running times:<b> 88 seconds </b><br>MVS running times:<b> 147 seconds </b><br>Mesh running times:<b> 56 seconds </b><br>Texture running times:<b> 61 seconds </b><br>Overall running times:<b> 5 minutes and 52 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.507 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3060 <ul></ul></li><li>Memory 12287 Mb <ul></ul></li><li>Clock 1777000 Khz <ul></ul></li><li>Processors 28 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 5 5600G with Radeon Graphics <ul></ul></li><li>Number of Cores 12 <ul></ul></li></ul><b>RAM </b><ul><li>Total 15709 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 140439 Mb <ul></ul></li><li>Total disk space 487658 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.507 |
00:05:58
101 |
162 |
55 |
40 |
25307eec6cf37fdf72b1dcfaab59a5c7 <h3>Benchmark Results</h3>SfM running times:<b> 101 seconds </b><br>MVS running times:<b> 162 seconds </b><br>Mesh running times:<b> 55 seconds </b><br>Texture running times:<b> 40 seconds </b><br>Overall running times:<b> 5 minutes and 58 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.502 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3080 Laptop GPU <ul></ul></li><li>Memory 16383 Mb <ul></ul></li><li>Clock 1365000 Khz <ul></ul></li><li>Processors 48 <ul></ul></li></ul><b>CPU </b><ul><li>Type 11th Gen Intel(R) Core(TM) i9-11900H @ 2.50GHz <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32583 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 552582 Mb <ul></ul></li><li>Total disk space 956944 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.502 |
00:06:03
105 |
199 |
33 |
26 |
2621983e3ed22c671e882ad618295455 <h3>Benchmark Results</h3>SfM running times:<b> 105 seconds </b><br>MVS running times:<b> 199 seconds </b><br>Mesh running times:<b> 33 seconds </b><br>Texture running times:<b> 26 seconds </b><br>Overall running times:<b> 6 minutes and 3 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.402 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3090 <ul></ul></li><li>Memory 24575 Mb <ul></ul></li><li>Clock 1860000 Khz <ul></ul></li><li>Processors 82 <ul></ul></li></ul><b>CPU </b><ul><li>Type 12th Gen Intel(R) Core(TM) i9-12900K <ul></ul></li><li>Number of Cores 24 <ul></ul></li></ul><b>RAM </b><ul><li>Total 130813 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 845115 Mb <ul></ul></li><li>Total disk space 1907089 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.402 |
00:06:13
94 |
176 |
55 |
48 |
58b45dc5c08a119b7284a04666571802 <h3>Benchmark Results</h3>SfM running times:<b> 94 seconds </b><br>MVS running times:<b> 176 seconds </b><br>Mesh running times:<b> 55 seconds </b><br>Texture running times:<b> 48 seconds </b><br>Overall running times:<b> 6 minutes and 13 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.503 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3090 Ti <ul></ul></li><li>Memory 24563 Mb <ul></ul></li><li>Clock 1950000 Khz <ul></ul></li><li>Processors 84 <ul></ul></li></ul><b>CPU </b><ul><li>Type Intel(R) Core(TM) i9-10980XE CPU @ 3.00GHz <ul></ul></li><li>Number of Cores 36 <ul></ul></li></ul><b>RAM </b><ul><li>Total 130748 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1844661 Mb <ul></ul></li><li>Total disk space 3814812 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.503 |
00:06:15
63 |
197 |
69 |
46 |
3f3079f1fd7db24e63f8c38df40a1bff <h3>Benchmark Results</h3>SfM running times:<b> 63 seconds </b><br>MVS running times:<b> 197 seconds </b><br>Mesh running times:<b> 69 seconds </b><br>Texture running times:<b> 46 seconds </b><br>Overall running times:<b> 6 minutes and 15 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 6.512 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3050 OEM <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1755000 Khz <ul></ul></li><li>Processors 18 <ul></ul></li></ul><b>CPU </b><ul><li>Type 12th Gen Intel(R) Core(TM) i5-12400F <ul></ul></li><li>Number of Cores 12 <ul></ul></li></ul><b>RAM </b><ul><li>Total 16222 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 170710 Mb <ul></ul></li><li>Total disk space 399360 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
6.512 |
00:06:23
94 |
180 |
66 |
43 |
40e7c8af1fb402b3627d4db4a5d2b8c4 <h3>Benchmark Results</h3>SfM running times:<b> 94 seconds </b><br>MVS running times:<b> 180 seconds </b><br>Mesh running times:<b> 66 seconds </b><br>Texture running times:<b> 43 seconds </b><br>Overall running times:<b> 6 minutes and 23 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.406 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3090 <ul></ul></li><li>Memory 24575 Mb <ul></ul></li><li>Clock 1695000 Khz <ul></ul></li><li>Processors 82 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen Threadripper 3960X 24-Core Processor <ul></ul></li><li>Number of Cores 48 <ul></ul></li></ul><b>RAM </b><ul><li>Total 130941 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 1359208 Mb <ul></ul></li><li>Total disk space 1907727 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.406 |
00:06:23
92 |
176 |
68 |
47 |
83eb5b82efa4818c9716e92ff825b3db <h3>Benchmark Results</h3>SfM running times:<b> 92 seconds </b><br>MVS running times:<b> 176 seconds </b><br>Mesh running times:<b> 68 seconds </b><br>Texture running times:<b> 47 seconds </b><br>Overall running times:<b> 6 minutes and 23 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3060 Ti <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1680000 Khz <ul></ul></li><li>Processors 38 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 9 3900X 12-Core Processor <ul></ul></li><li>Number of Cores 24 <ul></ul></li></ul><b>RAM </b><ul><li>Total 16324 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 53147 Mb <ul></ul></li><li>Total disk space 976109 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:06:25
100 |
165 |
65 |
55 |
137aa1b0a4ad9f5d4e9e7eaf8c6997d2 <h3>Benchmark Results</h3>SfM running times:<b> 100 seconds </b><br>MVS running times:<b> 165 seconds </b><br>Mesh running times:<b> 65 seconds </b><br>Texture running times:<b> 55 seconds </b><br>Overall running times:<b> 6 minutes and 25 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.511 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type Quadro RTX 4000 <ul></ul></li><li>Memory 8192 Mb <ul></ul></li><li>Clock 1545000 Khz <ul></ul></li><li>Processors 36 <ul></ul></li></ul><b>CPU </b><ul><li>Type Intel(R) Xeon(R) W-2225 CPU @ 4.10GHz <ul></ul></li><li>Number of Cores 8 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32495 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 145990 Mb <ul></ul></li><li>Total disk space 387352 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.511 |
00:06:28
93 |
199 |
56 |
40 |
31bbf64d91eb02167390a38cb63e4597 <h3>Benchmark Results</h3>SfM running times:<b> 93 seconds </b><br>MVS running times:<b> 199 seconds </b><br>Mesh running times:<b> 56 seconds </b><br>Texture running times:<b> 40 seconds </b><br>Overall running times:<b> 6 minutes and 28 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.406 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 2080 SUPER <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1845000 Khz <ul></ul></li><li>Processors 48 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 9 3900X 12-Core Processor <ul></ul></li><li>Number of Cores 24 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32689 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 45296 Mb <ul></ul></li><li>Total disk space 476312 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.406 |
00:06:32
123 |
171 |
56 |
42 |
d7bfd08a12d8c08b360400e223b80781 <h3>Benchmark Results</h3>SfM running times:<b> 123 seconds </b><br>MVS running times:<b> 171 seconds </b><br>Mesh running times:<b> 56 seconds </b><br>Texture running times:<b> 42 seconds </b><br>Overall running times:<b> 6 minutes and 32 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.406 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 2070 <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1815000 Khz <ul></ul></li><li>Processors 36 <ul></ul></li></ul><b>CPU </b><ul><li>Type Intel(R) Core(TM) i9-9900KF CPU @ 3.60GHz <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32686 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 146272 Mb <ul></ul></li><li>Total disk space 476383 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.406 |
00:06:37
85 |
193 |
72 |
47 |
6f5644ccff82ade6bf08af548ecb8117 <h3>Benchmark Results</h3>SfM running times:<b> 85 seconds </b><br>MVS running times:<b> 193 seconds </b><br>Mesh running times:<b> 72 seconds </b><br>Texture running times:<b> 47 seconds </b><br>Overall running times:<b> 6 minutes and 37 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.502 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 2070 <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1620000 Khz <ul></ul></li><li>Processors 36 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen Threadripper 2950X 16-Core Processor <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 130951 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 246849 Mb <ul></ul></li><li>Total disk space 909023 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.502 |
00:06:37
93 |
233 |
34 |
37 |
155ef81de35efee7309f56ddff190280 <h3>Benchmark Results</h3>SfM running times:<b> 93 seconds </b><br>MVS running times:<b> 233 seconds </b><br>Mesh running times:<b> 34 seconds </b><br>Texture running times:<b> 37 seconds </b><br>Overall running times:<b> 6 minutes and 37 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.017 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3090 <ul></ul></li><li>Memory 24575 Mb <ul></ul></li><li>Clock 1740000 Khz <ul></ul></li><li>Processors 82 <ul></ul></li></ul><b>CPU </b><ul><li>Type 12th Gen Intel(R) Core(TM) i7-1260P <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32399 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 244818 Mb <ul></ul></li><li>Total disk space 958307 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.017 |
00:06:41
105 |
168 |
84 |
44 |
a2e270448d5037a42238ecdddc004367 <h3>Benchmark Results</h3>SfM running times:<b> 105 seconds </b><br>MVS running times:<b> 168 seconds </b><br>Mesh running times:<b> 84 seconds </b><br>Texture running times:<b> 44 seconds </b><br>Overall running times:<b> 6 minutes and 41 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.500 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce GTX 750 Ti <ul></ul></li><li>Memory 2047 Mb <ul></ul></li><li>Clock 1137000 Khz <ul></ul></li><li>Processors 5 <ul></ul></li></ul><b>CPU </b><ul><li>Type Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32686 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 37682 Mb <ul></ul></li><li>Total disk space 228301 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.500 |
00:06:41
102 |
131 |
133 |
35 |
33f7295a009959796f5722efa14a1ae3 <h3>Benchmark Results</h3>SfM running times:<b> 102 seconds </b><br>MVS running times:<b> 131 seconds </b><br>Mesh running times:<b> 133 seconds </b><br>Texture running times:<b> 35 seconds </b><br>Overall running times:<b> 6 minutes and 41 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.511 <ul></ul></li></ul><b>No Cuda GPU Found </b><ul></ul><b>CPU </b><ul><li>Type AMD Ryzen 7 5800X 8-Core Processor <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65447 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 115222 Mb <ul></ul></li><li>Total disk space 242142 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.511 |
00:06:54
84 |
212 |
70 |
48 |
518045298ecff9d7d47085f634d5583f <h3>Benchmark Results</h3>SfM running times:<b> 84 seconds </b><br>MVS running times:<b> 212 seconds </b><br>Mesh running times:<b> 70 seconds </b><br>Texture running times:<b> 48 seconds </b><br>Overall running times:<b> 6 minutes and 54 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.507 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type Quadro RTX 3000 <ul></ul></li><li>Memory 6143 Mb <ul></ul></li><li>Clock 1380000 Khz <ul></ul></li><li>Processors 30 <ul></ul></li></ul><b>CPU </b><ul><li>Type Intel(R) Core(TM) i7-9850H CPU @ 2.60GHz <ul></ul></li><li>Number of Cores 6 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32575 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 59755 Mb <ul></ul></li><li>Total disk space 486761 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.507 |
00:06:56
118 |
196 |
53 |
49 |
5e8938a6560ba839303ff63088b247b5 <h3>Benchmark Results</h3>SfM running times:<b> 118 seconds </b><br>MVS running times:<b> 196 seconds </b><br>Mesh running times:<b> 53 seconds </b><br>Texture running times:<b> 49 seconds </b><br>Overall running times:<b> 6 minutes and 56 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.507 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 2080 <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1815000 Khz <ul></ul></li><li>Processors 46 <ul></ul></li></ul><b>CPU </b><ul><li>Type Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 65443 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 143443 Mb <ul></ul></li><li>Total disk space 456992 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.507 |
00:06:59
102 |
194 |
73 |
50 |
1b5fa6c132be144a59736e44a50d9783 <h3>Benchmark Results</h3>SfM running times:<b> 102 seconds </b><br>MVS running times:<b> 194 seconds </b><br>Mesh running times:<b> 73 seconds </b><br>Texture running times:<b> 50 seconds </b><br>Overall running times:<b> 6 minutes and 59 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 2070 <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1620000 Khz <ul></ul></li><li>Processors 36 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen Threadripper 2950X 16-Core Processor <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 130951 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 540525 Mb <ul></ul></li><li>Total disk space 909023 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:07:05
106 |
198 |
73 |
48 |
8f5dd2dbf483c157bcd9c519e6ac18d3 <h3>Benchmark Results</h3>SfM running times:<b> 106 seconds </b><br>MVS running times:<b> 198 seconds </b><br>Mesh running times:<b> 73 seconds </b><br>Texture running times:<b> 48 seconds </b><br>Overall running times:<b> 7 minutes and 5 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.507 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 2070 <ul></ul></li><li>Memory 8191 Mb <ul></ul></li><li>Clock 1620000 Khz <ul></ul></li><li>Processors 36 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen Threadripper 2950X 16-Core Processor <ul></ul></li><li>Number of Cores 32 <ul></ul></li></ul><b>RAM </b><ul><li>Total 130951 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 222420 Mb <ul></ul></li><li>Total disk space 909023 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.507 |
00:07:10
100 |
196 |
59 |
75 |
ca3641e20497c3f18bf6ab984d95ceb7 <h3>Benchmark Results</h3>SfM running times:<b> 100 seconds </b><br>MVS running times:<b> 196 seconds </b><br>Mesh running times:<b> 59 seconds </b><br>Texture running times:<b> 75 seconds </b><br>Overall running times:<b> 7 minutes and 10 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.517 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 3080 <ul></ul></li><li>Memory 10239 Mb <ul></ul></li><li>Clock 1710000 Khz <ul></ul></li><li>Processors 68 <ul></ul></li></ul><b>CPU </b><ul><li>Type AMD Ryzen 7 2700X Eight-Core Processor <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32675 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 354585 Mb <ul></ul></li><li>Total disk space 912614 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.517 |
00:07:16
142 |
203 |
51 |
40 |
cb0f9ebe3acd026dbade3d3e74a3c31b <h3>Benchmark Results</h3>SfM running times:<b> 142 seconds </b><br>MVS running times:<b> 203 seconds </b><br>Mesh running times:<b> 51 seconds </b><br>Texture running times:<b> 40 seconds </b><br>Overall running times:<b> 7 minutes and 16 seconds </b><br><h3>System info</h3><b>Application </b><ul><li>Version 7.405 <ul></ul></li></ul><b>GPU #1 </b><ul><li>Type NVIDIA GeForce RTX 4090 <ul></ul></li><li>Memory 24563 Mb <ul></ul></li><li>Clock 2595000 Khz <ul></ul></li><li>Processors 128 <ul></ul></li></ul><b>CPU </b><ul><li>Type Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz <ul></ul></li><li>Number of Cores 16 <ul></ul></li></ul><b>RAM </b><ul><li>Total 32702 Mb <ul></ul></li></ul><b>Disk </b><ul><li>Disk drive: C: <ul></ul></li><li>Available disk space 21906 Mb <ul></ul></li><li>Total disk space 803226 Mb <ul></ul></li><li>Solid state disk Yes <ul></ul></li></ul> |
7.405 |
